FS Front Wood Wheel Hubs
Post by TRDxB2 » Mon Sep 02, 2024 1:51 am
I recently purchased a barn load of T parts. In the process of sorting it all out so what I have is not limited to the following:
I have a number of front wood wheel hubs.No time to clean them up (de-grease) or check the bearings out and if I did the price would be higher. Doubt if the bearings are any good. I am checking hub cap threads & keyways etc. $35 a hub w flange ( plus shipping )
Also have a number of spindles with spindle arms attached. I have checked these out: all good threads, keyways & good for a tight inner race. Have both round collar & flat collar left & rights (no 1926/27) $30 each plus shipping.
Local pickup is available as well
Re: FS Front Wood Wheel Hubs with Tapered Bearings +
Post by TRDxB2 » Tue Oct 08, 2024 12:26 pm
still available
Post by TRDxB2 » Fri Oct 18, 2024 11:12 am
2 sets pending
Nikko012
First Name: Raymond
Last Name: Emling
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo, 1914 roadster, building:1910 roadster, 1911 touring
Post by Nikko012 » Fri Oct 18, 2024 8:22 pm
I am looking for thin ring hubs without the speedo ring cut.i am looking for Two sets with old bearing.can you help.
Can you send pictures of the pairs. Thanks Ray
Post by TRDxB2 » Fri Oct 18, 2024 11:55 pm
Don't have any
Nikko012
First Name: Raymond
Last Name: Emling
Post by Nikko012 » Sat Oct 19, 2024 2:09 pm
Do you have two match sets?
Nikko012
First Name: Raymond
Last Name: Emling
Post by Nikko012 » Sat Oct 19, 2024 2:14 pm
I will take Two sets, Please send pictures. Thin ring only,please.thanks Ray
Post by RajoRacer » Sat Oct 19, 2024 2:27 pm
What are you referring to as a "thin ring" Ray ?
VinTin23
First Name: Marty
Last Name: Ray
* REQUIRED* Type and Year of Model Ts owned: 1916 Runabout, 1922 Roadster
Post by VinTin23 » Sun Oct 20, 2024 4:55 am
I will take two sets, PM to follow.
Post by TRDxB2 » Sun Oct 20, 2024 10:14 am
Responded to your PM
Nikko012
First Name: Raymond
Last Name: Emling
Post by Nikko012 » Thu Oct 24, 2024 11:28 am
Have not heard from you on the two sets.
Thanks Ray
Post by TRDxB2 » Thu Oct 24, 2024 3:26 pm
Thanks Ray
Getting confused with two people each asking for 2 sets. Sent you a PM at 12.30pm Now I see you want two hubs, yes I have them will email you
Post by TRDxB2 » Thu Oct 24, 2024 3:27 pm
Getting confused with two people having RAY in their names & each asking for 2 sets. Sent you a PM yes I have them will email you
Nikko012
First Name: Raymond
Last Name: Emling
Post by Nikko012 » Fri Oct 25, 2024 6:33 pm
Great, thanks
Post by TRDxB2 » Wed Jan 08, 2025 8:24 pm
bump da bump
