WTB. Steering bracket for 'TT' Right Hand Drive.
v10pdownunder
Topic author - Posts: 24
- First Name: Ivan
- Last Name: Copping
- * REQUIRED* Type and Year of Model Ts owned: 24 TT, 13 T Roadster, 24 T Tourer
Part no. 3539C that attaches steering column to chassis rail. Will be made as mirror image of standard unit.
Most likely to surface in Australia, U.K., New Zealand or Argentina right hand drive markets ?
I could actually make use of 2 of them.
Re: WTB. Steering bracket for 'TT' Right Hand Drive.
I have one somewhere Ivan. It is not a mirror image of a LHD unit though. There is a cast in boss on the inside that goes to the frame rail. Perhaps all RHD ones were like this. I'll see if I can trip over it some time.
v10pdownunder
- First Name: Ivan
Thanks Allan, i await your contact.
Looking at several period parts books, it appears that the part number either duplicates with other parts or changes over years ? ?
The John Andrews, Ford agents in Auckland's parts listing for 1917 has a totaly different number.
I can well understand a 1917 parts book having a different number. Didn't the TT's come later than that?
v10pdownunder
- First Name: Ivan
As stated, it is a detailed book put out by agent in Auckland (under Colonial Motor Co umbrellar), but someone previously hand written date 1917 in it. Looks like actually late 1919 as covers trucks and tractors but still has war related content (WWI), but only lists parts for up to 1918 models.
Part numbers seem to vary fom USA listed numbers.
v10pdownunder
- First Name: Ivan
bump up to top
- Last Name: van Ekeren
My New Zealand parts book lists 2 for the TT 3539 RC 1918-21 then the new one to be able to mount the generator on the block, RHD, 3539 RE 1921-27
I found it Ian. Cast into the underside is TT 1924-B With the Ford script below and an A in a circle, most likely the maker's mark. It has only one hole, for the advance/retard rod, so will be for a generator equipped vehicle. Au$20 plus whatever the postage is.
