Clutch springs
hah
Last Name: hardiman
* REQUIRED* Type and Year of Model Ts owned: 26 coupe
Clutch springs
Post by hah » Mon Sep 09, 2024 12:03 pm
Howdy,
Seeing clutch springs advertised in classified section brings a question to mind. What is the compression rate (lbs) in one inch?
Thank you
Re: Clutch springs
Post by speedytinc » Mon Sep 09, 2024 12:21 pm
@ 2" should be 90#.
Any spring with less I pitch.
The new repops are 100-120#
hah
Last Name: hardiman
Re: Clutch springs
Post by hah » Mon Sep 09, 2024 2:11 pm
Does the added pounds affect operation of transmission? Improve performance or hinder operation?
Moxie26
Last Name: Jablonski
Re: Clutch springs
Post by Moxie26 » Mon Sep 09, 2024 2:15 pm
The new springs will lessen possible slippage in direct drive.
Re: Clutch springs
Post by speedytinc » Mon Sep 09, 2024 2:52 pm
Improves lock up. Less clutch slippage, which is adjustable to a point. @ diminished tension slippage may not be adjustable by increasing the tension with the 3 finger screws.
Real critical with TH400 clutches. Any slip wears the disks quickly. Eventually wearing away so much of the disks you have to replace them.
hah
Last Name: hardiman
Re: Clutch springs
Post by hah » Mon Sep 09, 2024 7:33 pm
Seems like, “common sense”, thank you all.
hah
Last Name: hardiman
Re: Clutch springs
Post by hah » Sun Sep 15, 2024 8:51 pm
Is there a clutch spring rated more than the 110lbs suitable for use in a racing T engine? Or is it sufficient to use the 110 pound spring?
Re: Clutch springs
Post by speedytinc » Sun Sep 15, 2024 9:59 pm
Racing spring? Not aware. Got info on them. Details?
The 110#(advertised) is the way to go for stock or th400 disks. (plenty)
I have the same spring with th400's behind a RAJO. Locks well enough to burn a little rubber In a full weight touring.
Erik Barrett
First Name: Erik
Last Name: Barrett
Re: Clutch springs
Post by Erik Barrett » Mon Sep 16, 2024 2:22 am
I always use the new ones in transmissions builds, especially if the customer requests a turbo or other modern lining clutch. They are not that expensive and good insurance.
