Since I am getting rid of the mag on the car I am installing oil slappers. My question is, how many oil slapper would you use, 2,4,6 or 8. Wondering if to many slappers will increase the pressure and not enough will not move the oil.
Thanks in advance
oil slappers
dinosbunny
Topic author - Posts: 341
- First Name: dino
- Last Name: marinelli
big2bird
- First Name: Jeffrey
- Last Name: Hausey
Re: oil slappers
I used 4......
- Last Name: Hatch
Re: oil slappers
One thing often overlooked when removing magnets is keeping the triple gear pins in place. Magnets keep the pins from backing out. Now I personally have not had that happen, I have seen the results.
When ever I remove magnets for someone, I require installation on a retaining ring.
Re: oil slappers
Dan,Dan Hatch wrote: ↑Fri Sep 13, 2024 4:04 amOne thing often overlooked when removing magnets is keeping the triple gear pins in place. Magnets keep the pins from backing out. Now I personally have not had that happen, I have seen the results.
I'm not saying that's not a valid concern, but I've got to question any triple pin that would tend to back out in the first place. If it's loose enough to back out, there's already trouble brewing and it'll reveal itself eventually, retaining ring, or not.
