Has anyone used this stabilizer?
WorldChamp1914
First Name: Gary
Last Name: Hagen
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
Post by WorldChamp1914 » Sun Sep 15, 2024 4:57 pm
I think Robbie Price has used it.
Re: Has anyone used this stabilizer?
Post by Allan » Sun Sep 15, 2024 6:26 pm
It will certainly wear grooves in the tie rod where the coil springs rub. There is a better version which has a cast arm mounted to the axle at the front and extending back to the wishbone ball. Both are designed to solve a nonexistent problem. However, if you chuck away all but the cast arm of the better version, you do have a set-up which might help with the problems of the earlier Above axle radius rod.
