FS Narrow Front & Rear Axle & Frame -Rail Car! Pending
Topic author - Posts: 6552
Was part of my Barn Finds. The front & rear axles have been narrowed & the frame shortened. Not the most attractive methods to shorten radius rods or the frame. Will take better pictures if interested just burried stuff in moving parts. $450 pick up only in Coal Valley IL. Its just 2.5 miles off Interstate 80 on US Highway 6. Have lots of other parts as well. Location is just 10 miles East of Craig Beek's Model T museum. Can arrange a tour of that too. Its on your way to/from Hershey. pending
Will make better map
South Park Zephyr
- Last Name: Francis
- * REQUIRED* Type and Year of Model Ts owned: 25 RPU, 27 Roadster
- Board Member Since: 2022
Re: FS Narrow Front & Rear Axle & Frame -Tractor/DoodleBug?
How narrowed are the axles?
I'll measure and take some measurements & add pictures with tape measure
South Park Zephyr
Thank you,
Scott
Scott
I emailed pictures but here again. There is also a modified wishbone
South Park Zephyr
I will check later today to see how close this is to what I need
Thank you
Scott
Thank you
Scott
South Park Zephyr
Frank,
I still waiting to hear from the organization that I’m building this project for to see if they have the range of measurements that will work for them.
I’ll left you know as soon as I hear from them
Thank you for your patience.
Scott
Scott
I have lots of patience and parts too, so if something else is needed I'm likely to have that too (no body parts though). I have an starter engine, needs rebuilding, that I haven't moved from the Barn yet. Some frames too if that's neededSouth Park Zephyr wrote: ↑Fri Sep 27, 2024 2:18 pmFrank,
Scott
