bolt source for fly wheel start ring
johnr
Topic author - Posts: 65
- Last Name: Delamater
- * REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
I am setting up an engine to be run without a magneto. any idea where i can obtain 1/4 x 24 bolts to attach the starter ring ?
- Last Name: Hatch
Re: bolt source for fly wheel start ring
For my money Dan M on here has the best slinger and bolt kit.
He also makes a ring to keep triple gear pins from backing out.
I will not remove magnets for customer without one of those kits.
johnr
Thank you for the reply. I already have the retaining ring and slingers made. looking for a source for the bolts to attach the starter ring.
big2bird
- First Name: Jeffrey
- Last Name: Hausey
Try Mc Master Carr.
- First Name: craig
- Last Name: leach
Hi John,
The 6mm will self lock in the threads so make sure the length is correct to tighten the ring gear.
I Get the length to stick out 1/6" additional & peen the ends.
I use lock washers also. That & the self locking nature of the close thread makes for a triple safe install.
Never had one come loose.
P.S. These bolts are for the original 14-24 thread. I have no experience with the current incorrectly threaded 1/4-24 ring gears.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
You can also retap the ring gear 1/4-28 and it will work just fine. As John mentioned you can also tap to a 6mm thread. Not sure I would just force the 6mm thread in to the ring gear.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Is this an item the vendors do NOT stock?
