I have some pieces of Mr Roadster brass glass setting channel
Dimensions of the pieces-
Large piece with radius on ends: 38” x 9 1/2”
Straight piece: 37 3/4”
2 short pieces: 11 1/2”
The straight piece and the two short pieces are mitered on the ends and form 90 degree angles. When assembled it makes a large frame… I have no idea what it was used for.
Then I have one heavy brass U channel that is 41 1/2” long. It has a hole drilled in one end and half a hole drilled on the other end. The glass channel does fit inside the u channel.
$50 for all plus shipping
mikebird@lifeattheridge.net
