Looking for a pair of Rocky Mountain brake bands for a 26 (buy or trade for earlier bands)
Reno Speedster
Topic author - Posts: 639
- First Name: Morgan
- Last Name: Blanchard
I have a new complete set of Rocky Mountain brakes for a small drum car, but I need a set for my 26 speedster. I checked with Chaffin’s, who normally carry the bands separately, and they are not available at the moment. I was planning to keep the parts for the small drum as spares for my 22 that has Rocky Mountains on already.
So, does anyone have a set of good Rocky Mountain 26-27 bands they would be willing to sell? I don’t need any of the other parts, just the bands. I would also be willing to swap my bands if someone has 26-27 bands and needs the earlier ones.
Last edited by Reno Speedster on Tue Oct 15, 2024 12:31 am, edited 1 time in total.
Re: Looking for a pair of Rocky Mountain brake bands for a 26 (buy or trade for earlier bands)
I dont think the mounting brackets are the same since the drums are not the same diameter. Further research is warranted.
Ed Fuller
- First Name: Ed
- Last Name: Fuller
- Board Member Since: 2012
John is correct. The small drum and large drum mounting brackets are different and will not interchange.
Reno Speedster
Sorry I did not make it clear. I am using custom brackets that support the Rocky Mountain brakes and drop the axle. So different brackets are not an issue for me. I just need the right bands.
- First Name: craig
- Last Name: leach
This comes up every once in a while. Has anyone considered having a piece of flat rolled into a ring & welded just a little smaller than the
26-27 drum, heat & press over the 26-27 drum, weld it on & have it turned or ground to the correct size for the larger drum? That would make
it a much more robust drum also.
NPorter56
- First Name: Neil
- Last Name: Porter
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT Truck
Hi - Don't know if these will work for you. I they are for TT Truck but fit on 26-27 drum. Band is a little too wide but don't think that matters.
I have three of these I was going to list for sale. Neil
Reno Speedster
If push comes to shove, I could make bands. But, I understand the parts will be available once things get back to normal for the folks who make Rocky Mountain.
I am not sure those bands are for Rocky
Mountains. They have a bracket I don’t see on the ones I have.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
The bands that Neil posted pictures of are late '20s Chevrolet and will work just fine on 26-27 drums. If you are making brackets, just design them to work with the Chevy bands. Or- call Bud Williams an buy just buy the RM bands from him.
Tinner12
- First Name: Vernon
- Last Name: Enis
- * REQUIRED* Type and Year of Model Ts owned: 1917 and 1924 touring,1926 4 door
- Board Member Since: 2011
are these what you need
- Attachments
- IMG_0777.jpg (29.58 KiB) Viewed 1902 times
- IMG_0776.jpg (29.73 KiB) Viewed 1902 times
Tinner12
- Last Name: Enis
these say pat 4-6 -23 on them and RH and LH Cleveland
Reno Speedster
Very cool, but not what I am after.
