Shop tip
BobShirleyAtlantaTx
Topic author - Posts: 361
- First Name: Bob
- Last Name: Shirley
Shop tip
Please post tips that make things easier IE, Use an opened old magazine under gaskets, when applying sealant. When through just turn the page and the mess is sealed in.
Doug Keppler
- First Name: Douglas
- Last Name: Keppler
Re: Shop tip
This is an amazing trick I learned, when siliconing say a bathtub or anything you want a straight clean line, run a strip of masking or painters tape along the edges on both sides before you lay the bead, smooth it with a wet finger and peal off the tape while the silicone is still wet, you will have a perfect clean silicone line like a professional
1924 Touring car
There's No Substitute for Proper Lubrication
- Last Name: Wrenn
Re: Shop tip
Yep Doug...been using that trick forever! Really works nice.
babychadwick
- First Name: Chad
- Last Name: Azevedo
Re: Shop tip
A little grease in a socket or wrench can hold that nut to get it started. While on the topic of grease place some grease in a bag with a bearing to work the grease in without messing up your hands.
Tim Williams
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
Re: Shop tip
Nice thread topic
What about fishing line through band adjustment nut, in case it falls into pan. That is one I heard about.
Doug Keppler
Re: Shop tip
When looking for a short in your car, disconnect the ground cable from the battery and hook up a test light from the cable end to the ground terminal of the battery then pull fuses from the fuse box one at a time till the test light goes out. You will now know what circuit the short is on.
1924 Touring car
It's Bill
- First Name: Bill
- Last Name: Hoffer
Re: Shop tip
When attempting to free a rounded over and rusted on nut, try speaking the following incantation: $#£÷*@×&€$!!!!%÷$#??. Don't forget the ×&. Cheers, Bill
Rich Bingham
- First Name: Rich
- Last Name: Bingham
Re: Shop tip
Translation : "Rippin strippin cornsarn dang fang zarg barga ding-dong !"
Works every time !
"Get a horse !"
Doug Keppler
Re: Shop tip
Very funny Bill, Im partial to "Mother Father Cocker Spanial"!!!
1924 Touring car
Ruxstel24
- Last Name: Hanlon
Re: Shop tip
Be sure you have a WORKING fire extinguisher in an accessible location. Or a couple, depending on your shop size...
- First Name: Dennis
- Last Name: Seth
Re: Shop tip
When I take something apart that has many different small pieces I use an egg carton to hold them in. You have 12 or 18 different compartments to place them in, label the lid just above the compartment and can close the lid to keep them all together.
When painting screw heads, bolts, or parts I stick them in a piece of Styrofoam so they stand up and you can get all the edges.
