FS 11 tooth pinions ( non script sold)
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Oct 18, 2024 11:50 am
FS Pinions 11 tooth One Ford script with some small pits (copper colored) & one non script $ 50 each + the ride
Last Name: van Ekeren
Re: FS 11 tooth pinions
Post by Kerry » Fri Oct 18, 2024 6:11 pm
It could be possible that the one with the dot is a later one and needs to match a ring gear with a dot as well.
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Oct 18, 2024 7:02 pm
Hi Frank,
To the best of my knowledge that is that dot is a hardness test mark I certainly hope its not as I have never seen a ring gear with a dot?
Every ford script pinion I have seen I believe has that dot. It is also on the other end of the gear.
First Name: craig
Last Name: leach
Re: FS 11 tooth pinions ( non script sold )
Post by Craig Leach » Tue Oct 29, 2024 10:46 pm
To the top. All of the pits in the Ford script pinion are in the pics. They do not appear to be rust or flaking. looks to have been run long after
they where made.
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Tue Oct 29, 2024 11:47 pm
Hello Craig, we haven't spoken for quite a while. I'm looking forward to an update. I would like to buy the one on the left.
Ken
Work honestly
Stay true to your word
Get the job done right
First Name: craig
Last Name: leach
Re: FS 11 tooth pinions ( non script sold)
Post by Craig Leach » Wed Oct 30, 2024 10:06 am
Non script pinion sold Thanks Ken.
