1913 "T" hoodformer question
Craig E. Luton
First Name: Craig
Last Name: Luton
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Post by Craig E. Luton » Wed Oct 23, 2024 6:02 pm
Did the 13 hoodformer use polished brass screws or painted screws?
Thank you Craig
Re: 1913 "T" hoodformer question
Post by DanTreace » Wed Oct 23, 2024 6:07 pm
This info on older post may help.
By John F. Regan on Monday, June 21, 2010 - 09:39 am:
Since your hood former is not factory made - the dimension I have may or may not be correct but original hood formers were mounted with the bottom end at 3/4" above the top surface of the frame. Place a board 3/4" thick on top of your frame and set the hood former on it and you are at the original height if your hood former were original. Ford alternated from time to time between having pilot holes predrilled and then having them "drilled in place" and it is obvious that the 3/4" dimension was not a "must" since I have seen cars with slightly different dimensions so consider that a starting point and adjust your hood for good fit. Ideal fit would be with the edges of the hood just barely above the hood clash strips that are sitting on top of the frame rails at the sides of the hood. Hood former was held to dash with #10 polished oval head slotted brass screws on the 1911-1912 cars and I don't think this changed through 1914.
Post by Allan » Wed Oct 23, 2024 6:36 pm
Follow Dan's advice and use the suggested 3/4" from the frame as a guide only. Then fit the hood. Now you can check the fit of the hood. The former can be moved about on the firewall until you get the best fit for the hood. Once you have that, fix the former in that position. The hood is not adjustable, the radiator position likewise, so moving the former about is the way to go for a good hood fit.
When i pieced together my 1912 van the former was offset 1/2" to one side and almost 1' above the frame. The off centre position is not noticeable at all.
