Found one/Wanted- 1914 runabout door latch
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Thu Oct 31, 2024 12:10 pm
I’m looking for a door latch for my runabout. I’ve determined that there were 2 different ones, don’t know if it was because of 2 body makers or what but the handle is in a slightly different spot. The one I need has the handle closer to the rear.
It is easily identifiable by where the handle goes into the latch assembly. The one I have is the one where you can see a space there and the one I need has a round part integral with the handle that fills in the round hole in the latch and no light can be seen on either side.
I bought an interior from a car with this style latch and the hole for the handle off enough that it won’t go through and the panel fit the door correctly. I had a post on the forum a while back on this and was suggested to bend my handle but that won’t make a difference because it still would originate in the same position and not go through the hole regardless if it were bent one way or the other.
Email- wlkma9@gmail.com
Or call/text (903)-681-2871
Corey Walker
First Name: Corey
Last Name: Walker
Re: Wanted- 1914 runabout door latch
Post by Corey Walker » Thu Oct 31, 2024 12:12 pm
A couple pics of mine and the interior still fitted to the car with the style latch I need.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Nov 01, 2024 5:19 pm
Cory,
I've got this one:
Keith
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Nov 01, 2024 5:22 pm
Do you need the striker plate for the door jam, too?
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Sat Nov 02, 2024 12:15 am
Keith, I have the striker plate. Unfortunately I have the same latch that you have there already. The one that you can’t see the light through where the handle goes in is a shorter distance from the handle to the rear of the latch. It’s only a 1/2 or 3/4” difference but it makes a difference to match the hole in my door panel that came from a car with that type latch. Thanks though.
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Sat Nov 02, 2024 9:48 am
This is the latch that Corey needs, it is on the 14 that the interior came out of. Art
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Sat Nov 02, 2024 12:05 pm
Thanks Art, yes that is the one with no daylight showing around the handle. The other style that I have now is 2 1/4” at the spot where the other is 1 1/2”.
