FS high rad shell $100
fordrelic
First Name: Clay
Last Name: Atkins
* REQUIRED* Type and Year of Model Ts owned: 1921 Roadster
Post by fordrelic » Sun Nov 03, 2024 11:05 am
For Sale high radiator shell.
This is a brass/nickel shell that will need cleaning.
The issue is on inside one vertical edge is is cracked, see picture.
I thought maybe someone could silver solder?
$125 plus shipping.
t shell foot.jpg (29.08 KiB) Viewed 1949 times
BarnesvilleT
First Name: William
Last Name: Hallada
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Coupe
Re: FS high rad shell
Post by BarnesvilleT » Sun Nov 03, 2024 7:37 pm
Do you have the bottom flange on the left side?
fordrelic
First Name: Clay
Last Name: Atkins
Post by fordrelic » Mon Nov 04, 2024 7:43 am
its there, but it's hard to see in pictures. I can take closeup if you are interested.
BarnesvilleT
First Name: William
Last Name: Hallada
Post by BarnesvilleT » Mon Nov 04, 2024 12:45 pm
Thanks for posting the photos. I am not sure I have the ability to fix that long split.
I think I will look for others but will contact you if I am not successful to see if it is still
available.
Thanks,
Bill H.
Post by Allan » Tue Nov 05, 2024 5:37 pm
Bill, rather than a split, it is most likely a wear groove due to a poorly fitted hood. These are quite common on brass shells. It can most satisfactorily be fixed by folding a brass strip to lay along the inside of the shell and silver soldering it in place through the wear groove. This will require some skill by the solderer. If the rest of the shell is not beaten up, it is a worthwhile repair job.
fordrelic
First Name: Clay
Last Name: Atkins
Re: FS high rad shell $100
Post by fordrelic » Thu Nov 14, 2024 5:02 pm
$100 plus shipping
fordrelic
First Name: Clay
Last Name: Atkins
Post by fordrelic » Sun Nov 17, 2024 7:44 am
$100 plus shipping
fordrelic
First Name: Clay
Last Name: Atkins
Post by fordrelic » Wed Nov 27, 2024 8:08 am
$100 plus shipping approx. $30
fordrelic
First Name: Clay
Last Name: Atkins
Post by fordrelic » Thu Dec 05, 2024 7:45 am
to the top
