Ford shop coat
Grntea
First Name: David
Last Name: Tagert
* REQUIRED* Type and Year of Model Ts owned: 1926, 1925, 1923, 1921, 1918
Ford shop coat
Post by Grntea » Mon Nov 04, 2024 9:54 am
I am very interested in getting a Ford shop coat like the one pictured below. If you have one and are not using it - I would appreciate a chance to put it to good use!
Grntea
First Name: David
Last Name: Tagert
Re: Ford shop coat
Post by Grntea » Tue Nov 05, 2024 3:30 am
Back to the top please! Thank you MTFCA
Last Name: Hjortnaes
Re: Ford shop coat
Post by DHort » Tue Nov 05, 2024 6:10 pm
sent you an IM
Grntea
First Name: David
Last Name: Tagert
Re: Ford shop coat
Post by Grntea » Thu Nov 07, 2024 7:11 am
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Re: Ford shop coat
Post by tom_strickling » Thu Nov 07, 2024 1:29 pm
Check out the Early Ford v-8 museum in Auburn Indiana. The have a White shop coat in their gift shop
https://early-ford-v-8-foundation.squar ... se&q=false
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
CDooREDW
First Name: Ron
Last Name: Wenzel
* REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
Re: Ford shop coat
Post by CDooREDW » Thu Nov 07, 2024 4:59 pm
All,
I called the Piquette Plant and they gave me the link for the holiday specials where can be found the Piquette shop coat and coveralls.
https://www.jotform.com/form/242654985288171
Regards,
Ron in HSV
Re: Ford shop coat
Post by DHort » Thu Nov 07, 2024 7:04 pm
Early Ford V-8 museum only has Medium in stock. If it is like the brown one above, I am 5'8", 160 pounds and can just fit it. Not tight, but not loose either. Just an FYI.
Wish they had a pic of the front to see if it has the buttons with a flap to prevent scratching.
I tried getting white coveralls made by Red Kap thru Amazon. They must all be modeled by someone 5'6" tall and a Eunuch. I tried different models and sent them all back because they were tight over the shoulders. I think I have to go to Indy and try on what they have before I will find one that fits.
TeveS-Nor Cal
Last Name: Straw
Re: Ford shop coat
Post by TeveS-Nor Cal » Fri Nov 08, 2024 1:34 pm
I have 2 for sale. 1 medium and 1 large. Both worn about two times- like new condition.
