Camshaft
vanco
Last Name: Van Cott
Camshaft
Post by vanco » Sat Nov 09, 2024 4:08 pm
Wanted: Camshaft, new or used , or acceptable core for a regrind.
Re: Camshaft
Post by RajoRacer » Sat Nov 09, 2024 5:03 pm
What year ?
t-time
Last Name: Bruto
* REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Re: Camshaft
Post by t-time » Sat Nov 09, 2024 8:45 pm
try egge machine in Ca they usually have regrinds outright
vanco
Last Name: Van Cott
Re: Camshaft
Post by vanco » Sat Nov 09, 2024 10:22 pm
Steve, my block is early, (9-29-15).
vanco
Last Name: Van Cott
Re: Camshaft
Post by vanco » Sat Nov 09, 2024 10:25 pm
Thanks Mark!
Last Name: Hatch
Re: Camshaft
Post by Dan Hatch » Sun Nov 10, 2024 5:46 am
Use 26/27 to keep from having front bearing knock.
If you were closer I got a 5 gal bucket full.
Randall strickland
First Name: Randall
Last Name: Strickland
Re: Camshaft
Post by Randall strickland » Sun Nov 10, 2024 8:15 am
kevin pruse has new cams
Randall strickland
First Name: Randall
Re: Camshaft
Post by Randall strickland » Sun Nov 10, 2024 8:16 am
kevin 330 774 7130
Re: Camshaft
Post by RajoRacer » Sun Nov 10, 2024 12:18 pm
I don't have much in late cam cores but have plenty of early BUT Dan H.'s suggestion is worth considering - I believe the new cams are the late style.
vanco
Last Name: Van Cott
Re: Camshaft
Post by vanco » Sun Nov 10, 2024 5:23 pm
Dan, Randall and Steve, Thanks for you advice!!
First Name: craig
Last Name: leach
Re: Camshaft
Post by Craig Leach » Mon Nov 11, 2024 10:53 pm
Hi John ,
If you end up with a early cam I have one shim kit left.
