Gas Headlamp Orientation
Jones in Aiken SC
First Name: Gregory
Last Name: Jones
Post by Jones in Aiken SC » Sat Nov 09, 2024 6:51 pm
Question about 1912 gas John Brown headlamps. Looking at the front of the car, which way are the gas headlamps put on? Hinges inside or outside? In other words, again looking at the front of the car, are the hinges on the far left of the passenger lamp and on the far right for the drivers side? Thumbnuts on the inside or outside? I suppose I could do it either way but am curious as to what is "original."
Last edited by Jones in Aiken SC on Sat Nov 09, 2024 9:10 pm, edited 1 time in total.
First Name: Keith
Last Name: Townsend
Re: Gas Headlight Orientation
Post by KWTownsend » Sat Nov 09, 2024 8:24 pm
Greg,
I'll look at some of my photos from the era. I would suspect they are mounted hinges out for easy lighting.
Acetylene powered lights are headlamps.
Keith
Drkbp
First Name: Kenneth
Last Name: Parker
Post by Drkbp » Sat Nov 09, 2024 9:53 pm
With John Browns from Ford, 1912 - 1914, depended on what two headlamps you got.
Here is a '12 with two JB lefts and another with two JB rights (hinges).
E&J's of this time period were all lamp hinge left.
Since you have a L & R "pair", I like the knurled knobs out on mine so I can close and
secure the lamp away from the radiator (especially on relighting}.
LAMP HINGE LEFT
LAMP HINGE LEFT
LAMP HINGE RIGHT
LAMP HINGE RIGHT
Mark Chaffin
Last Name: Chaffin
Re: Gas Headlamp Orientation
Post by Mark Chaffin » Sun Nov 10, 2024 11:39 pm
Early 13' John Brown headlamps. Hinges outboard. Nuts inboard.
Post by Allan » Mon Nov 11, 2024 2:34 am
If you had E and J lights you'd have nothing to fritz about. They are all the same. From the previous post, the same could apply to different mixes of brown lamps too.
Jones in Aiken SC
First Name: Gregory
Last Name: Jones
Post by Jones in Aiken SC » Mon Nov 11, 2024 11:58 am
The reason I asked is because I looked at several old photos of original T's and found a wide variety of how the headlamps were mounted. Some hinge inside, some outside, etc. Of course, lamps could have been changed around so who knows. Not sure of the lamps in the attached photo but they have hinges on the left side. Are these E&J or Brown?
Just wondering if there was an "original from the factory" convention. One of those anal details, you know........I do however plan to mount them as per Mark Chaffin's post above, so I guess it is academic. Just curious.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Tue Nov 12, 2024 6:22 am
Pic above are John Brown.
Drkbp
First Name: Kenneth
Last Name: Parker
Post by Drkbp » Tue Nov 12, 2024 9:45 am
Last photo is an example of what seems to happen often,
the headlamps are one supplier and side lamps another.
In this case, the side lamps are E&J.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Tue Nov 12, 2024 10:36 am
I spent a moment puzzling over this too. Interesting Mark’s “untouched” ‘13 has lamps with hinges outboard.
Also interesting to learn not all lamp mfgrs. made “pairs”. Not a big thing, I mounted mine hinges inboard as the lenses can touch the fenders the other way.
Get a horse !
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Tue Nov 12, 2024 10:41 am
Early 13' John Brown headlamps. Hinges outboard. Nuts inboard.Screenshot_20241110_203642_Gallery.jpg
Do I see light bulbs?
Post by DanTreace » Tue Nov 12, 2024 11:50 am
Yep, has later reflector so is electrified, did the same on my pair of old, beat up and missing parts Victor lamps.
The later Ford reflector fit the bucket, and the later Ford script rims in brass (were nickel plated) fit too by just riveting the hinges and latch parts to the rims. ;)
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Tue Nov 12, 2024 12:26 pm
Actually, they are original accessory inserts to convert to electric headlights. The gas burners and reflectors remain in place behind the electric bulb and reflector. Neat accessory for sure.
Post by RajoRacer » Tue Nov 12, 2024 5:04 pm
Our '14 has all matching JNO. Brown lights and the headlamps have the hinges outboard - I'm the 3rd owner but can't verify if the lamps were ever swapped.
