Starter mounting gasket thickness?
signsup
Topic author - Posts: 472
- First Name: Robert
- Last Name: Brough
- * REQUIRED* Type and Year of Model Ts owned: 1915 War Wagon 1927 Depot Hack 1927 TT
In a bind and can't get a gasket to install my rebuilt starter in time for an event this weekend. Dan has one in AL but it's a couple hour drive and some gas money just for a gasket.
I see the pattern on the vendors site but not the thickness of the gasket. Don't know if this is just paper or rubber or cork or what. Thinking of purchasing cork gasket meterial from local auto parts store and tracing the pattern around my starter and using some gasket setting goop. Can someone share with me what the approximate thickness of this gasket should be so I can purchase the correct size flat sheet of cork?
I'll hang up and listen.
Thanks in advance.
Thanks in advance.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
A bunch of old cars
Sometimes they run.
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Starter mounting gasket thickness?
Any gasket material from the local auto parts store will do. Thickness is not critical.
And if the store is closed, cut a gasket from the cardoard that hods a six pack together.
Some people skip the gasket and use sealant only.
signsup
- Last Name: Brough
The next time my wife tells me to throw something away, I'll remind her of this scenario ...no, I don't sleep with this under my pillow, just used it as a backdrop. Found it in the T parts stash. FYI the thickness is 5 business cards.
But, nice to know I had some options.
Thanks to all.
Thanks to all.
A bunch of old cars
Sometimes they run.
A bunch of old cars
Sometimes they run.
RecklessKelly
- Last Name: Maxson
- * REQUIRED* Type and Year of Model Ts owned: 1926 model t coupe
The one I brought online is 1/32", same as the one I took off.
signsup
- Last Name: Brough
The one that came off was so gooped onto the bell housing that I had to use a scraper to get it off and it felt like paper, then rubber, then paper again, so I had no idea what the original was supposed to be. Now I know. Bubba may have used that six pack cardboard and a tube of CRV silicone. I will try to use just enough to hold the gasket in place while assembling the starter.
A bunch of old cars
Sometimes they run.
A bunch of old cars
Sometimes they run.
You will also need a gasket for the bendix cover. The bendix must be installed after the starter is in place. If you try to install with it on the starter it will brake the magneto. These two gaskets must be sealed well because the engine oil is thrown around that area from the flywheel.
Make a gasket from a shoebox. Make another one for the bendix cover while your at it.
When installing either one use a gasket sealer to hold them in place and make sure you use a thin coat on the outward side. Works every time.
Bubba probably used some gobbed on sealer also around the transmission cover to keep it leaking at the corners. They’ve been known to leak at those areas also.
