FS 1920 Roadster
J1MGolden
Last Name: Golden
FS 1920 Roadster
Post by J1MGolden » Tue Nov 26, 2024 12:30 pm
For Sale 1920 Roadster, Engine and Transmission completely rebuilt by Kevin Prus with a Z High Compression Head. New Kevlar Bands were installed later, and driven about 2,400 miles since then. New Radiator and new hoses. 4 New RiversideTtires and Tubes with a good spare. New wire harnesses. Good generator and starter. New semi-conductor reverse current diode. New firewall. New heavy duty 1/0 gauge correct battery cables. New April 2022 6 volt battery. New rear axles and seals. Brass thrust washers in the rebuilt rear axle. New front spindle bushings. New tie rod bushings. New pitman arm and cap. All worn front wheel bearings and cups replaced. New headlight reflectors. New safety glass windshield. New top, top boot, leather straps and saddles. Custom made side curtains. New kick panels. New drive shaft bushing. Rebuilt NH carburetor. Rebuilt original coils. New floor mat. New muffler. New packing nut. New stainless exhaust pipe. New fan belt. New Anderson timer. Modern Zerk type grease fittings added. Hassler shocks with original grease fittings. Running board tool box with two new keys made to fit. Turn signals and added rear turn signal/ brake lights. Dual original cast iron side mirrors. Original set of 1920 Maryland license plates. Car is located in Silver Spring, MD. $15,000 or Best Close Offer! Email Jim Golden for additional information.
1920 Side.jpg (72.93 KiB) Viewed 8736 times
Re: FS 1920 Roadster
Post by Jerry VanOoteghem » Tue Nov 26, 2024 2:28 pm
That is one very nice car!!
J1MGolden
Last Name: Golden
Post by J1MGolden » Tue Nov 26, 2024 4:57 pm
It was bought in Ohio a few years ago and looked that good then.
MariaDenesik
First Name: Maria
Last Name: Denesik
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T Speedster
Post by MariaDenesik » Tue Dec 10, 2024 6:20 am
Hi Jim, I'm very interested in the 1920 Roadster you have for sale. The extensive rebuild and new parts are impressive. Could you provide more details about the car’s condition and any additional photos? Please let me know if it's still available. Thank you! Writing a thesis can be daunting, especially on a budget. I decided to try the cheap thesis writing service at https://academized.com/cheap-thesis academized and it was a great choice. The thesis was well-written, detailed, and met all the academic standards. Despite the affordability, the quality of the work was exceptional. The process was straightforward, and the delivery was on time. I highly recommend this service to anyone needing quality thesis help without overspending.
