These are many of the patters I made up using 3D printing to make the many brackets/hardware for a Ford Delivery Car.
Note: This pile is not all of the patters as many of the other pieces are simply flat pieces of steel such as door bumper plates, door lock guides, stop plate and floor skids skids.
All these pieces are 3D printed and can serve in aiding in making the brackets out of steel and helping with the construction/dimensions of the Delivery Car body. The main drawing of the body can be obtained from The Henry Ford.
Here is what is included in this pile:
Front seat brace LH, RH
Rear seat brace
Side pillar/Rear door jamb brace
Front seat riser/pillar brace RH, LH
Rear fender iron (I used this pattern to have the irons cast as original)
Front seat moulding
Roof and plaster brace
Door lock lever (I used this one to have the door lock lever cast as original)
All the drawings for these can be obtained from the Henry Ford. All these patterns were made to the exact Ford drawings.
$550 plus shipping
mikebird@lifeattheridge.net
1912 Delivery Car patterns SOLD
Tbird
Topic author - Posts: 1361
- First Name: Mike
- Last Name: Bird
