demountable Transmission band orientation
johnr
Last Name: Delamater
* REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Post by johnr » Tue Dec 03, 2024 11:14 am
In placement of the bands in the transmission is the removalable ear required
to be oriented in a specific direction ? Towards the pedal side or opposite side or low speed
adjustment?
Or does it not matter ?
Thank you.
J1MGOLDEN
Last Name: Golden
Re: demountable Transmission band orientation
Post by J1MGOLDEN » Tue Dec 03, 2024 11:20 am
The removable ear must be on the driver's side or it can disconnect and fall in the transmission.
Fozz71
Last Name: Chochole
Board Member Since: 2003
Post by Fozz71 » Tue Dec 03, 2024 11:22 am
To be able to remove and install, you'll want the removable ear side on the driver's side when complete, that way you can slide the band, without the ear, all the way around inside the trans and "fish" it up the pedal side. With the ears on it gets harder.
Luxford
First Name: Peter
Last Name: Kable
Post by Luxford » Tue Dec 03, 2024 4:40 pm
For the record, if its RHD the opposite is the case. as the drums are still turning the same way as LHD its a simpler answer.
The reason being the room to work the bands around the drum is greater in both LHD and RHD hogshead because of the pedals position in the hogs head making it easier to do, some put them in the opposite way, it still works but is more difficult but nothing happens that matters.
Bands coming undone has never been a problem which has shown up. If they fell off they weren't put on correctly.
Its a myth that the ear can fall off, it can't. If the band is in place the only way the ear can come off is if the band can turn while the ear stays still that can't happen unless the band can grab the drum, and that can only happen when the pedal clamps the band ear to reduce the bands diameter.
Last Name: Hjortnaes
Post by DHort » Tue Dec 03, 2024 10:33 pm
John
This summer I was driving my red speedster in the homecoming tour. We crossed the Ohio River and headed up a 1000 foot hill. At the top my low pedal dropped to the floor and I lost all forward motion. That was it for me. That was it for me that day. Park it and ride all the way back to the museum with Dave Nolting and his wife, who were gracious enough to share their front seat with me. Dave's wife was kind enough to sit in the back.
When I opened up the transmission and started removing the hogshead the removable ear popped off the band and dropped. It was on the passenger side. Turns out I had 2 Ford bands and one generic band. Guess which one popped apart? They were all good and tight when we installed them backwards only a few months before.
Now all 3 bands are now installed with the removable ears on the LEFT (drivers side).
johnr
Post by johnr » Wed Dec 04, 2024 1:01 pm
Thank you all for the information
John
