Mechanical tach setup?
Eric Edwards
First Name: Eric
Last Name: Edwards
* REQUIRED* Type and Year of Model Ts owned: 1909 Town Car 1925 Morton and Brett Fronty 1911 RHD Torpedo 1912 Touring
Post by Eric Edwards » Sun Dec 08, 2024 10:35 pm
Has anyone put a mechanical tach( Stewart Warner or ? On a cable drive off the generator? What do we do to get the ratio of rpm correct? Any thoughts. ? Thanks. any ideas welcome. Eric
Dodge
First Name: Dodge
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Re: Mechanical tach setup?
Post by Dodge » Sun Dec 08, 2024 10:55 pm
1955-1959 Corvette
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Dec 08, 2024 11:16 pm
Hi Eric,
They are not very common anymore but S.S. White & Stewart Warner used to sell speedometer calibration gear boxes that did just that. They
can be made to almost any ratio & can be placed on the drive or inline of the cable. I used one to calibrate a Stewart Warner speedo in a sports
car I built in 1998 that used VW center of wheel cable drive. It would have to slow it down 33.3%?? for a T using the generator to drive it as that
is driven @ 150% of crank speed.
Eric Edwards
First Name: Eric
Last Name: Edwards
Post by Eric Edwards » Mon Dec 09, 2024 12:39 am
That’s what i wanted to know. You are astute
Thank you so much. I saw a car in Michigan that ran a drive off the back of the generator but just didn’t know the reduction ratio or what to do. You’ve answered what i was needing to know. Thanks so much. Brilliant. Thanks Eric
Eric Edwards
First Name: Eric
Last Name: Edwards
Post by Eric Edwards » Mon Dec 09, 2024 12:47 am
