What's this?
love2T's
Topic author - Posts: 300
- First Name: T
- Last Name: Gates
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1926 Fordor
What's this?
Posting for my friend Joe...he acquired this "thing" attached to a block. Wants to know if anyone's seen anything like it and exactly what's it for or does. Thanks!
Mike Silbert
- First Name: Mike
- Last Name: Silbert
Re: What's this?
That is an oil pump driven off the back of the cam.
These are custom so I can not tell you who made the pump and setup.
Mike
Mike
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Re: What's this?
Air cooled VW oil pump. Some were set up to simply pump oil to the front to assist the splash system, while others went to full pressure bearings. The block should not have been modified too badly. Maybe just a couple extra holes
Joe Bell
- First Name: Joe
- Last Name: Bell
Re: What's this?
Is this a VW oil pump? I am not familiar with this setup was wondering if tube on top was for priming, this was a fresh rebuild with A crank but has set for many years, thinking of using this with my four valve Rajo but would love to know who else has done something like this or do i need to change whole setup from what some one has created. Thanks Tim for posting since, i have not figured it out how to do this on this sight.
Re: What's this?
Link explains the different years & sizes of the early VW oil pumps and flow direction https://www.jbugs.com/VW-Tech-Article-VW-Oil-Pumps.html
Lots of additional info here https://www.google.com/search?client=fi ... pump+mtfca
