Interested in one with the corner brackets still attached.
Might consider pre 26-27 with corner brackets also.
Scott Elliott
971-5O6-94O2
WTB: 26-27 Rear Cross Member
FATMAN
- First Name: ROBERT
- Last Name: BERGSTADT
Re: WTB: 26-27 Rear Cross Member
I have some ,Bob
- First Name: craig
- Last Name: leach
Hi Scott,
Did you find a cross member to your liking? If not I have a 27 frame with the right frame rail bent near the front. The frame can be cut off
anywhere that suites your needs.
