WTB outer races NEW
Tim D
Last Name: Dickson
* REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
WTB outer races NEW
Post by Tim D » Fri Dec 27, 2024 5:03 pm
looking for 2 new Timken outer front races.
Walt Wise
First Name: Walt
Last Name: Wise
Re: WTB outer races NEW
Post by Walt Wise » Fri Dec 27, 2024 5:37 pm
Post by TRDxB2 » Fri Dec 27, 2024 10:20 pm
Last Name: Hjortnaes
Post by DHort » Fri Dec 27, 2024 10:45 pm
Never hurts to buy spare races and bearings from RockAuto. Just keep them in the box on the shelf. When you need one, they will be out of stock and no one else will have it in stock.
Post by TRDxB2 » Sat Dec 28, 2024 1:28 am
Never hurts to buy spare races and bearings from RockAuto. Just keep them in the box on the shelf. When you need one, they will be out and no one else will have it in stock.
I'll second that. And once RockAuto is out-of-stock the new price will be higher than before
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Sun Dec 29, 2024 1:50 pm
I dont want to take over a thread that isnt mine, but are the rock auto outer bearings threaded? If they are the picture isn't right.
Post by DHort » Mon Dec 30, 2024 1:39 am
Austin
Yes. They are threaded.
Use this chart. I think I got it from Steve.
Bearings, Front Wheel.jpg (45.31 KiB) Viewed 4707 times
Post by TRDxB2 » Mon Dec 30, 2024 10:38 am
What picture are you referring to? The numbers are the same as in the chart.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Mon Dec 30, 2024 1:19 pm
Thanks all. It makes sense to me now.
A full order, minus seals, comes out to be a little over $200 plus shipping, tax, and the other 8 yards.
An outer race like the O.P. wants is $7.74 each.
Tim D
Last Name: Dickson
Post by Tim D » Mon Dec 30, 2024 4:42 pm
Thank you . Never thought about RockAuto for this. Buy other things from them.
Post by DHort » Wed Jan 01, 2025 3:29 am
Austin
Yes, Rockauto used the wrong photo for the bearings. Just go by the numbers. You will get the right item.
Post by TRDxB2 » Wed Jan 01, 2025 10:57 am
Just a heads up. I think you'll find that many Major supplier use "representative" images of a product to convey the a general view of the product. In the case of the RockAuto photos when the are zoomed in show a general roller bearing likely used for all roller bearings they sell. If you scrolled across the the arrows there are 4 images. So don't always expect the image to be the desired product, which means further checking is needed
Interestingly enough the TIMKEN site makes no mention of "threaded"for the bearing
https://cad.timken.com/item/tapered-rol ... rial/09075
