23 speedometer cable
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Tue Dec 31, 2024 11:42 am
What is the correct length for a 23 touring?
What was the original finish on it?
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Re: 23 speedometer cable
Post by Russ_Furstnow » Tue Dec 31, 2024 12:31 pm
If you have a Stewart speedometer and the swivel is placed ahead of the axle, the length is 60", and the finish is black. I hope this helps, Russ Furstnow
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Tue Dec 31, 2024 12:43 pm
Yes, it does. Thank you.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Tue Dec 31, 2024 12:50 pm
I have a 60" and a 66". 60" will go on the car.
What would the 66 be for? Just curious.
RVA23T
Last Name: C
Post by RVA23T » Tue Dec 31, 2024 1:05 pm
Back/Mother-in-law seat driver speedo placement ;)
Post by Allan » Tue Dec 31, 2024 9:51 pm
The longer cable may be called for if the speedo drive is mounted on the other side of the car to the speedo. This is sometimes necessary if the swivel joint runs in the opposite direction to normal for a T. Swivels can be LH or RH rotation.
