need to have castings made
Tim D
Last Name: Dickson
* REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Post by Tim D » Tue Jan 07, 2025 4:56 pm
Looking for a company to cast four cast iron brake shoes not T. Have one casting that is soso but ok for a pattern.
JR Ewing
First Name: Joshua
Last Name: Ewing
* REQUIRED* Type and Year of Model Ts owned: 1918 Ford Model T Roadster, 1936 Ford Pickup (I know, not a T)
Re: need to have castings made
Post by JR Ewing » Tue Jan 07, 2025 5:15 pm
Sand casting or investment?
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Tue Jan 07, 2025 5:35 pm
what size are they? I made some patterns years back for a big brass car, still have the patterns, have a local foundry that likes my old junk to parts.
Post by Jerry VanOoteghem » Tue Jan 07, 2025 6:13 pm
If Joe's source doesn't pan out, you could try Cattail Foundry, in PA. https://goodsstores.com/blogs/a-good-wo ... nnsylvania
https://www.chamberofcommerce.com/busin ... il-foundry
Pat Branigan Wisc
Last Name: Branigan
* REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
Post by Pat Branigan Wisc » Tue Jan 07, 2025 7:41 pm
Tomahawk Foundry, Rice Lake Wisconsin.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Tue Jan 07, 2025 8:46 pm
Looks like you've got three suggestions with this one being in your state. Good Luck.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Wed Jan 08, 2025 6:53 am
Just remembered these where for a Jackson car
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Wed Jan 08, 2025 7:22 am
Tim, IMO the best for what you are needing is Windy Hill Foundry ( https://windyhillfoundry.com/ ). You will need to draw it up and then 3D print what you need. Reach out to Clark and see if he can't make what you need. Text me if you have any questions or wanna talk about this.
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Fri Jan 10, 2025 12:01 am
I put juice brakes on my 1909 Stoddard Dayton. I went to the NAPA store and got a cast iron brake drum catalog. I found the diameter drum I needed. It had cooling fins on the outside and was 1" to deep.
I chucked the drum up and turned the drum down and ended up with the correct diameter for my external brake band. I cut the dept of the drum down to work with my brake bands. I drilled the necessary holes to bolt the drum to the spokes.
The drums were cheap a little bit of lathe time and I saved a lot of money over making patterns and casting the drums. Keep in mind you still have to machine the new cast drums. The drums I used were mid 60's Pontiac Tempo for about $24 each.
Just sayin,
frontyboy
Post by Allan » Fri Jan 10, 2025 1:52 am
Tim is looking for brake shoes. It did not take long for auto makers to develop fabricated steel brake shoes. Even 26-7 Ts had steel shoes, albeit with cast ends. It may be easier to fabricate what you want, especially with computer cutting available these days. Casting is not a common practice in workshops, unlike fabrication.
