Tractor Train Brakes
Post by Original Smith » Thu Jan 16, 2025 6:18 pm
San Diego Tour, last Sunday. I live 100 miles north of Sand Diego, so had to hit the road at 4:30 am to get there on time. It was nice talking with new people I don't usually see. The car that I found interesting was a 1914? touring car with original Rocky Mountain brakes. But they were not what I'm used to seeing. I got down low, and saw they are in fact the second design made by Tractor Train. I've only seen parts for those, but never installed in a working car. I should have rolled under the car and looked more carefully, but from what I saw they were authentic. You never know!
Re: Tractor Train Brakes
Post by DanTreace » Fri Jan 17, 2025 4:31 pm
Larry
Was is the key difference in the 2nd design? Figured the 'R-M' by Tractor Train looked like this adv.
tractor train.jpg (94.89 KiB) Viewed 2892 times
And saw these "Perfection Brakes" on a touring, made in Cinn. OH, adv dated 1919. They have 160 sq. in. brake surface compared to R-M of 106 sq. in. surface. Features metal lugs around every other spoke to provide security to the wood wheel too ;)
IMG_8378 (474x530) (402x450).jpg (115.77 KiB) Viewed 2892 times
Post by Allan » Fri Jan 17, 2025 5:55 pm
I have a sneaking suspicion that My Moore gearbox in my roadster buckboard was made by the Tractor Train Transmission Co. I'll have to get under the car to check.
Post by DanTreace » Fri Jan 17, 2025 8:33 pm
Highly likely ;)
Post by Allan » Fri Jan 17, 2025 9:45 pm
Thanks Dan. You have saved me from having to clear a path and getting down under the car. It is still awaiting its transplant following broken crankshaft.
Post by Original Smith » Sat Jan 18, 2025 1:49 pm
I should have rolled under the car when I saw it, but we were on a tour and I didn't feel like rolling under someone else's car! I have several of the brackets made by tractor train and could never figure out the purpose of the extra reinforcing tab on the bracket. The ones I saw last Sunday are the only ones I've seen in use on a car. I'd like to have seen the equalizer, and brake pedal clamp on the car too.
