5-Z-1170 wood wheel hub puller
namdc3
First Name: Nikolaus
Last Name: Martin
Post by namdc3 » Tue Jan 21, 2025 11:45 pm
Is this a 5-z-1170? I can’t find a part number on it, and the overall shape is a little different than in the image. That said, I’ve seen several variants of the 5-z-287, too. It is script and fits a T hub (not a 1171 TT puller). The center striker bolt matches the Ford image. If someone has one, is it marked with a part number and where? Thanks.
namdc3
Last Name: Martin
Re: 5-Z-1170 wood wheel hub puller
Post by namdc3 » Tue Jan 21, 2025 11:47 pm
namdc3
Last Name: Martin
Post by namdc3 » Wed Jan 22, 2025 10:10 am
July 1926 Ford Service Bulletin
Post by Mark Gregush » Wed Jan 22, 2025 10:44 am
Glad I got one of the later wood wheel pullers like shown, so much beefier in construction. LOL on the part about light taps! Har-har! :lol:
namdc3
Last Name: Martin
Post by namdc3 » Wed Jan 22, 2025 9:22 pm
Mark, is it Ford script, and does it have a Z number on it?
Post by Mark Gregush » Thu Jan 23, 2025 4:26 pm
Same script as one shown above. On the other side is the company's logo that made it (can't read it). No Z number that I could find.
namdc3
Last Name: Martin
Post by namdc3 » Thu Jan 23, 2025 5:43 pm
Thanks, Mark. There seems to be comparatively a lot of 1172 pullers, but I have not come across any photos of 1170 pullers to compare this to. It was probably not as popular of tool since there were many other wood wheel hub pullers to choose from.
Post by Mark Gregush » Fri Jan 24, 2025 8:44 am
The style of wood wheel puller shown came out late in the game so there are fewer examples. I am glad I got mine; it was made so much better than some of the lighter versions.
Like the Z wire wheel lug wrench, the Ford wire wheel hub pullers are fewer in between, not as many out there which also reflects in price. There were only so many shops working on the T's and with the wire wheels hubs, there were other way to pull the hubs off that could also be used on other brands of cars so could be that that puller was just not sold in any quantity to the general public.
Post by Allan » Sat Jan 25, 2025 12:07 am
Nikolaus, your puller is likely an aftermarket item. I have never seen a Ford one which does not have an octagonal end which allows the hubcap wrench to be used to wind it onto the hub. Your six sided one will require its own wrench to use it.
I believe early Chevs and some Essex models had the same fine thread on the hub as a T model, so perhaps it is made for one of those.
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
Post by KBurket » Sat Jan 25, 2025 12:16 am
I have one like yours. It has the ford script and a makers mark but no part number. I haven’t figured out the makers mark.
It came out of the attic of my grandfather’s garage that opened in the1910s.
namdc3
Last Name: Martin
Post by namdc3 » Mon Jan 27, 2025 6:44 pm
Allan, that’s a good observation about the hex vs octagon. They are Ford script, so not another make of car, but it’s possible that the script was licensed out.
KBurket, great photos. I don’t think mine has that foundry mark, but I will look again.
Harley_97
First Name: Roger
Last Name: Hallett
* REQUIRED* Type and Year of Model Ts owned: 1924 Runabout, 1917 Runabout
Post by Harley_97 » Mon Jan 27, 2025 8:06 pm
Is this the type of wheel puller for the TT? It does have the ford script. On the left side of the slit are 2 illegible markings, to the right side is 25. No other markings found.
Roger
Post by speedytinc » Mon Jan 27, 2025 8:50 pm
Show a picture of the threads. looks like a T puller, not TT.
Post by RajoRacer » Mon Jan 27, 2025 9:27 pm
The TT puller is identical to the car puller - just alot bigger ! I'll get a photo for a side by side comparison tomorrow.
Post by Allan » Tue Jan 28, 2025 4:33 am
Roger, yours is just like mine. Note the octagonal end which allows it to be screwed onto the hub with the help of the toolkit hubcap wrench.
Alan from down under.
namdc3
Last Name: Martin
Post by namdc3 » Tue Jan 28, 2025 7:36 am
Roger, that is probably the earlier 3-z-605 or 5-z-287, both for the T hub. Sometimes the numbers is on the inside cavity. In 1926 Ford came out with the heavier 5-z-1170 with center strike bolt.
Harley_97
First Name: Roger
Last Name: Hallett
Post by Harley_97 » Tue Jan 28, 2025 11:27 am
After a bit of light sanding, it is a little clearer, the Z can be seen. At the bottom of the slit I can see the bottom portion of the 6, to the right what I thought was a 2 is actually a zero and the 5 after that. In front of the Z there was something stamped; to faint to make but the rest of charters tell the story, 3z605.
Harley_97
First Name: Roger
Last Name: Hallett
Post by Harley_97 » Tue Jan 28, 2025 11:30 am
Also, the letter B is seen on the inside.
Roger
