Aluminum intake manifold
Tmooreheadf
Topic author - Posts: 445
- First Name: Tom
- Last Name: Moorehead
Looking for an aluminum intake manifold needed to mount A carb to an T engine. Anyone have such?
- Last Name: Tannehill
- Board Member Since: 2002
Re: Aluminum intake manifold
Try eBay .
Mark Chaffin
- Last Name: Chaffin
Your looking for a Zenith manifold. Not reproduced. You need to find and original.
Tmooreheadf
- First Name: Tom
Just lost one on eBay, got out bid. Continuing to look!
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Not sure if these sidedraft manifolds are still being reproduced. I made up the elbow adapter for the Winfield and it worked great. Don’t those Zenith manifolds get really restrictive in the dogleg…?
- First Name: craig
- Last Name: leach
Hi Tom,
I was way under on that one on eBay too.
Are you running a generator most updraft
Manifolds/A carb combinations will not clear
a generator. Offset manifolds are hard to find
If you have a early engine or run a alternator
That eBay up draft manifold will work with a
Tillison X or Shebler carb. The Winfield manifolds
Currently available can be used by making a adapter that moves the carb back & away
from the engine.
from the engine.
Can’t you use the intake from a A or B model on a T?
Yes on the Model A maybe B too but you would need to redo the throttle rod to use and might need to use the exhaust in conjunction. You don't need the adapter plate to use it.
Tmooreheadf
- First Name: Tom
We are looking into the “A” intake. There are several considerations to be worked out if we make that change! We’ll keep monitoring EBay and auctions.
popeyet
- First Name: CHRIS
- Last Name: MCINTYRE
- * REQUIRED* Type and Year of Model Ts owned: 21 touring, 15 roadster
- Board Member Since: 2023
I have this one: I sent you an internal message.
UPDATE: If Tom is not interested, this manifold and lever is available. Give reasonable offer. SALE PENDING
Karl Von Neumann
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
I thought I had it made with the one I found but the carb flange is the wrong way
- First Name: craig
- Last Name: leach
Hi Tom,
I don't think I have ever seen a A manifold with a T exhaust ( other than a vaporizer exhaust manifold? & changing to a A manifold W/ exhaust
is more work.) The manifold in Kevin's pic I believe is a speedway manifold modified to use a Winfield carb. That is the third one I have seen
& I'll bet none of them are for sale. The Zenith manifold is as rare as the carb is, & if Chris is interested in parting with the lever I would be
interested as I don't have that part & will need to make it. Karl that is the more desirable set up if you can find all the parts to the carb.
I was told in the past that the Zenith manifold with the lever on the side was the reproduction and the one Karl shows is the original because the carb Karl shows is the original type that came with the manifold and use the original Ford style carb rod.
- First Name: craig
- Last Name: leach
Zenith made carbs with the bolt pattern both ways. The O4 Zenith bolts are inline I have one just like the one Mark posted.
Yes the carb is on backwards to show the model # But this may be a aftermarket manifold that was referenced because the word Zenith
is different than most or could be a later production??
