What is this ford wrench for?
ClockDoc
Last Name: Grabowski
* REQUIRED* Type and Year of Model Ts owned: 1924 Fordor
Post by ClockDoc » Fri Jun 21, 2019 5:23 pm
I’m wondering what this ford wrench is for? Has Ford script with U.S.A. on one side and the letter M on the other.
Last Name: Seth
Re: What is this ford wrench for?
Post by perry kete » Fri Jun 21, 2019 6:34 pm
OK, Everyone knows that I'm the forums resident smart a$$ so I'll answer...
"What is this wrench used for?"
It's used to tighten Nuts on bolts! :roll: :roll: :roll:
Tractordoc
Last Name: Barclay
* REQUIRED* Type and Year of Model Ts owned: 1920 coupe
Post by Tractordoc » Fri Jun 21, 2019 7:47 pm
Sorry I can't help it. If you turn it around you can use it to loosen bolts and nuts also.
Post by Mark Gregush » Fri Jun 21, 2019 8:19 pm
It would be Ford Model A up including tractors. Not T and not band adjusting wrench. The openings are ether 1/2-9/16 or 9/16-5/8.
ClockDoc
Post by ClockDoc » Sat Jun 22, 2019 10:03 am
Thank you Mark, much appreciated.
