Hogshead weight
JBog
First Name: Jason
Last Name: Bogstie
Hogshead weight
Post by JBog » Sat Jan 25, 2025 8:43 pm
Does anyone know the weight of a cast iron Hogshead?
Re: Hogshead weight
Post by Allan » Sun Jan 26, 2025 1:21 am
It depends on how many times you have tried to fit it after a band change. They put on weight with each attempt. :D
Re: Hogshead weight
Post by DanTreace » Sun Jan 26, 2025 8:13 am
33.0 lbs. 1925 Transmission Cover with Cover, High Speed Clutch Assembly and No reverse or brake Pedals
32.0 lbs. 1926 Transmission Cover with High Speed Clutch Assembly and No reverse or brake Pedals
