Wrong U-Joint
mortier
First Name: Philip
Last Name: Jamison
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Wrong U-Joint
Post by mortier » Fri Feb 07, 2025 3:34 pm
I just got a U-Joint off eBay for my '15 T (the one in primer), but looks like I made a mistake. What is this one off of?
Last Name: van Ekeren
Re: Wrong U-Joint
Post by Kerry » Fri Feb 07, 2025 4:27 pm
Accessory transmission uni.
Re: Wrong U-Joint
Post by speedytinc » Fri Feb 07, 2025 4:32 pm
Are you guessing or do you "know"??
Which accessory transmission?
Last Name: House
Re: Wrong U-Joint
Post by George House » Fri Feb 07, 2025 5:26 pm
I had one like that for a Muncie Accy T transmission…..
Or was it 2 ‘female’ shafts ?
Re: Wrong U-Joint
Post by speedytinc » Fri Feb 07, 2025 5:37 pm
Muncie uses a special short female end that is also a bearing race. Female square into trans.
I have seen shortened, stock U-joints that apparently work with no bearing support surface.
I have a NOS, Ford script, U-joint as OP shows. Looks factory assembled. Mistake??
I thought it might be for a PTO on a Fordson, since there are a few out there, but have not seen conclusive evidence.
Re: Wrong U-Joint
Post by Jerry VanOoteghem » Fri Feb 07, 2025 7:01 pm
The rivets on the one in primer are not done by the factory. See how crude the peening is? It appears that someone made this version for some special purpose. Maybe to drive a PTO pulley???
Re: Wrong U-Joint
Post by speedytinc » Fri Feb 07, 2025 8:11 pm
Mine looks to be factory riveted once.
I get your point. & the 2 rivets seen are in 2 different directions on OP's.
