Budd wire wheel questions
fordrelic
First Name: Clay
Last Name: Atkins
* REQUIRED* Type and Year of Model Ts owned: 1921 Roadster
Post by fordrelic » Wed Feb 19, 2025 9:44 am
A friend is needing help mounting Budd wheels to model T.
Is there someone that he could call to get information he needs?
Thanks for the help.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Budd wire wheel questions
Post by Kevin Pharis » Thu Feb 20, 2025 11:49 am
Most hubs for Budd wire wheels were made to fit Overland cars. Hubs to fit Ford cars did exist, but are far more uncommon. I hear it is possible to adapt the Overland hubs to fit the Ford axles, but have no specifics as to the effort required
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Tue Feb 25, 2025 12:55 am
Having been using Budd wire wheels on a number of t projects over the years, I found a sure fire easy way to mate your Overland rear hubs to model t axles.
Get 2 26/27 inner wooden wheel rear hubs. Machine these inner hubs to lightly press fit into the Overland rear hubs. Then I tig weld the t inner hub to the Overland hub front and back.
Now you have an Overland hub that will slide on the fit the t axle. You use the t axle nut and pin it and you have the project done for a minimum of cost and effort.
I've converted the front hubs a bit more work and effort. If you machine a dutchman to fit between the Overland inner hub where the bearing race, you can machine the Dutchman to press into the that space and size it to fit the model t race. Overland bearings are much larger in diameter that stock t bearings.
just sayin'
brasscarguy
