Timer selection ?
Dave1
Last Name: Eddie
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Timer selection ?
Post by Dave1 » Wed Mar 12, 2025 5:02 pm
What is the current Go-To timer ?
I have tried the Anderson timer, which I was not happy with .
Had great success with the TW timer, however it is no longer available.
Dave
Mark Nunn
Last Name: Nunn
Re: Timer selection ?
Post by Mark Nunn » Wed Mar 12, 2025 5:20 pm
I have an E-Timer that works flawlessly. I don't have a magneto and 6 volts was not up to the task. If you have a working mag, I recommend the I-Timer.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Wed Mar 12, 2025 8:31 pm
I have been using the roller type timer. They last about 1600 miles then the internal surface gets lumpy, which causes misfiring. Additionally the roller requires cleaning and oiling every few hundred miles.
An ANCO (flapper) timer interests me. This design requires good alignment between the camshaft and timing gear cover. The initial accuracy of the timer itself seems to be good. This accuracy was checked with a tool that I made using an old camshaft, timing gear cover, and a timing gear.
Many owners like the New Day Timer. These will not work so well in oily conditions.
Art Mirtes
Post by Steve Jelf » Wed Mar 12, 2025 10:33 pm
I've been using New Day for many years. Some of the repops have been trash, but the current version has received very favorable comments from people who know their Model T stuff.
Dodge
First Name: Dodge
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Post by Dodge » Wed Mar 12, 2025 10:55 pm
New Day timers for the past 70yrs. in our family.
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Thu Mar 13, 2025 9:00 am
I've used an E-Timer for about the last ten years, and enjoy its trouble free performance. Importantly, it stays that way because of no parts moving against each other.
Inthegarage
Last Name: Mosher
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster pick up
Post by Inthegarage » Thu Mar 13, 2025 9:01 am
I’ve been using a E timer about three years now with great success.
John Codman
Last Name: Codman
Post by John Codman » Thu Mar 13, 2025 10:52 am
I bought and installed a Lang's 3221 roller timer on September 17, 2014 and haven't had any trouble with it since that date. The only problem is that I don't see that timer listed in the latest catalog that Lang's has sent me (2021).
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Thu Mar 13, 2025 11:19 am
Dave...check your email. I may be able to help.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Thu Mar 13, 2025 2:46 pm
The catalogs from Snyder's and from Gaslight show roller timers. You would have to contact them to determine if they actually have them.
Art Mirtes
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Thu Mar 13, 2025 2:50 pm
John Codman,
Your roller timer has been in your car for ten years. What's your secret to its long life. I cannot get a year out of one. I drive about 2000 miles per year.
Art Mirtes
Post by RajoRacer » Thu Mar 13, 2025 3:00 pm
Have you "set" your timing cover with the proper gauge ?
Post by Norman Kling » Thu Mar 13, 2025 5:13 pm
New Day or Anderson is what I have used. Once set correctly they work very well. The guage does not work on all timers. Best to see where the spark actually occurs with your timer and Then bend rod to fit with the lever all the way up.
Post by RajoRacer » Thu Mar 13, 2025 5:21 pm
Timing cover, Norm - not the spark lever ! One needs to correctly "set" the timing cover for concentricity !
Moxie26
Last Name: Jablonski
Post by Moxie26 » Thu Mar 13, 2025 5:26 pm
The. " Gauge " is only to be used with the stamped Ford timer... In all practicality. ..... . Other timers should be set according to their enclosed instructions.... And the timer rod lengthened or shortened according to the timer initial setting with the timer lever fully up..... Not all timers are the same.
Post by Allan » Fri Mar 14, 2025 12:12 am
A report on timer longevity is useless if time alone is measured. A more useful indication of worth is how many miles of service it has given.
I concur with the E timer users. The lack of moving parts making any contact means absolutely no wear. Set and forget is the way to go. I do have to remember that I must run it on battery, unlike the rest of my T's. The True-fire in my chocolate van is just as good.
Last Name: Hjortnaes
Post by DHort » Fri Mar 14, 2025 1:32 am
I-timer. Set it and forget it.
