Timer cover 1911-1919
ModelT46
Topic author - Posts: 1664
- First Name: Darel
- Last Name: Leipold
Here is a early time cover, perhaps 1911-1915. If you know the exact year, post that here. The cover is $75 plus the ride. I will consider offers.
- Attachments
- cover back.JPG (114.97 KiB) Viewed 911 times
- cover ft.JPG (113.48 KiB) Viewed 911 times
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Re: Timer cover 1911-1919
Late ‘12 to early ‘13 timing cover with “small” oil scoop. This is also the cover that works with the 3 gear Bosch magneto side drive
RGould1910
- Last Name: Gould
See how it also has a u shaped channel for holding the fely
