Wheeler muffler
Topic author - Posts: 1495
- First Name: Keith
- Last Name: Townsend
Wheeler muffler
Does anyone have any information about one of these?
- First Name: Adrian
- Last Name: Whiteman
Re: Wheeler muffler
I particularly like the description: "Motor Testing Valve"
TMiller6
- First Name: Thomas
- Last Name: Miller
- Board Member Since: 2006
Re: Wheeler muffler
134 East Jefferson is now the entrance of the Detroit-Windsor Tunnel.
Tom Miller
KBurket
- First Name: K
- Last Name: Burket
Re: Wheeler muffler
Older post discussing wheeler and other home made versions.
http://www.mtfca.com/discus/messages/82 ... 1530408436
- First Name: Keith
Re: Wheeler muffler
Appears to be similar in size to a standard T muffler outlet.
- First Name: Keith
Re: Wheeler muffler
I believe this was fabricated with Model T muffler ends. I'm thinking that outlet port s a little small...
- First Name: Keith
Re: Wheeler muffler
I'm curious about the construction.
The pipe from the manifold is about 1-1/2" in diameter.
It is welded onto a pipe that is about 3" in diameter.
Does the 1-1/2" pipe go farther into the 3" pipe?
The muffler part looks to be made from late stamped muffler ends.
I suppose the center shell is not used, but the middle one is used?
The 3" pipe on the end has a butterfly valve to open for straight pipe, or divert exhaust through the other shell.
I would like to see a cutaway diagram.
Thanks,
Keith
Thanks,
Keith
