Magneto Field Coil
W Austen
First Name: Bill
Last Name: Austen
Magneto Field Coil
Post by W Austen » Tue Jun 25, 2019 2:36 pm
Who rebuilds the Model T Magneto Field Coils? I have 3 early field coils that have been checked cleaned and coated that I plan to sell in the near future.I need to have a double stack 1915 coil rebuilt, but can't remember who does the rebuilding. Thanks MTFCA
W. Austen
tdumas
First Name: Ted
Last Name: Dumas
* REQUIRED* Type and Year of Model Ts owned: 1927 Coupe, 1924 Touring
Re: Magneto Field Coil
Post by tdumas » Tue Jun 25, 2019 5:45 pm
Total Recoil. Google for contact info.
Post by Steve Jelf » Wed Jun 26, 2019 12:23 am
Wally Szumowsky sold Total Recoil and retired, and the new owner has since died. Has anybody else taken it over? If not, you may need to turn to Birdhaven, Bob's, Chaffin's, Lang's, etc. (Google Total Recoil and you get video games.) :)
HalSched
First Name: Hal
Last Name: Schedler
* REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Post by HalSched » Wed Jun 26, 2019 1:01 am
If anyone knows how to contact Wally S I'm sure he would know. If you have a lot of time you can do it yourself. I did.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Wed Jun 26, 2019 1:11 am
R.V. Anderson rewinds Mag coils.
Hers is a link to his profile.
memberlist.php?mode=viewprofile&u=795
Respectfully Submitted,
Be_Zero_Be
Post by DanTreace » Wed Jun 26, 2019 8:26 am
Another good source:
Post by Mark Gregush » Thu Jun 27, 2019 11:38 am
If the 3 have only been cleaned and checked, at this point, unless they have been completely rebuilt they are still cores. Any coating you put on isn't going to stick for very long to old oily surfaces and the old probably rotted wrappings. If the the insulator between the winding's is still good, you might get by with un-soldering the connections between the coils, re-wrapping the coils, sand blasting the frame, reassembling, coat and bake.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Thu Jun 27, 2019 11:42 am
First, what Mark said.
Next, I do rewind field coils; have done many thousands using all new copper, insulators, contact blocks, etc. Everything is new but the frame itself. Surface grinding available. All units carry a lifetime warranty.
rvmodeltATnetsyncDOTnet
Dan B
Last Name: Blaydon
Post by Dan B » Sun Jun 30, 2019 9:19 pm
Do yourself a favor get the pole faces and the ring to block surface ground so that they are flat and parallel. It will make getting the proper air gap easy.
W Austen
First Name: Bill
Last Name: Austen
Post by W Austen » Sun Jul 07, 2019 4:46 pm
