Starting a Model T
Gary
First Name: Gary
Last Name: Cryer
* REQUIRED* Type and Year of Model Ts owned: 1923 Model T Roadster
Starting a Model T
Post by Gary » Mon Apr 14, 2025 7:12 pm
Trying to start my Model T after it has sat for 14 years. Any suggestions?
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Re: Starting a Model T
Post by tman1913 » Mon Apr 14, 2025 7:52 pm
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Mon Apr 14, 2025 11:18 pm
Having been through the exercise when I first got my car, there's two things that would have saved me a lot of hassle.
First thing is to make sure the valves are sealing and there's a usable amount of compression - otherwise it will never start.
Chances are the fuel system has dirt in it, and the float valve in the carburettor won't shut off. Either that, or there's not enough fuel flow due to blockage.
Obviously, make sure each spark plug actually fires - timer and coil box contacts could be tarnished after a long period of disuse. Engine oil should be changed after that long of a period too - it's likely to have deteriorated, and may have water in it.
zrusscher
First Name: Zaeden
Last Name: Russcher
* REQUIRED* Type and Year of Model Ts owned: None Yet, Hope for a 23-27 Touring
Post by zrusscher » Tue Apr 15, 2025 2:35 pm
Here's an article that I think you might find helpful by Milt Webb:
https://www.mtfca.com/discus/messages/2 ... 303258.pdf
