Can someone tell me thickness of the wood blocks between the running board brackets and boards on my 1926 T?
Thanks in advance.
Mike
Wooden Spacers for 1926 running boards
varmint
- First Name: Vernon
- Last Name: Worley
Re: Wooden Spacers for 1926 running boards
Mike, I know the blocks are available from the vendors for cheap:
https://www.snydersantiqueauto.com/prod ... 2277&cat=0
But I made mine custom to fit whatever condition our T was in, sagging and straightened brackets. The measurement I have probably won't help you.
Vern (Vieux Carre)
Mike Silbert
- First Name: Mike
- Last Name: Silbert
According to previous posts the blocks should be 3/4" x 1 1/2"
http://www.mtfca.com/discus/messages/29/33961.html
http://www.mtfca.com/discus/messages/29 ... 1170435525
Measuring my early 1926 Touring they are 3/4" x 1 3/8" x about 9".
These are factory original 99 year old running board blocks
Make them fit inside the running board for the exact length.
Mike
Mike
jab35
- Last Name: Bartsch
I made these from a scrap piece of plastic deck board, thinking they would absorb less water/moisture and contribute less to rust on underside of running boards. FWIW, jb
36mike
Topic author - Posts: 40
- First Name: Mike
- Last Name: Russell
- * REQUIRED* Type and Year of Model Ts owned: 1926 Runabout, 1922 Pickup Express,
Thanks everyone. After I posted my question, I found an original block. I figured there was some shrinkage and came to the conclusion that 3/4" was the right thickness. I looked around for an Oak scrap and didn't find one so I made some temporary spacers from pine. I also thought about some sort of length-wise reinforcement from front to back but decided it might become a moisture trap. Thanks again.
Mike
Mike
