WTB windshield 22 Touring Found, pending pickup
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Tue Apr 22, 2025 9:56 pm
I am looking for a usable windshield frame for a 1922 touring with a two-man top. It has the rounded corners on the top half. I am also looking for and oil lamp bracket/windshield mount for the left hand side only. I only need the two windshield halves, I have a set of usable hinges. Preferably without glass or good usable safety glass. Does not have to be a showpiece, as long as it functions as intended.
Thank you!
Austin Farmer
Freeport illinois.
My old one got bit by the garage door, and bent up and broke the frame. Parts mught be savable, but for now, I would like to just find a useable one.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Re: WTB windshield 22 Touring
Post by Karl Von Neumann » Tue Apr 22, 2025 11:06 pm
I may have one here in pleasant prairie wi not terribly far from you ill take a look may even have one with glass. Your top window doesn't look hurt
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Wed Apr 23, 2025 1:32 pm
I would be interested. The top is better than the bottom but is damaged, and broke the glass, I was able to bend it back mostly but was left with a large dent where the windshield wiper goes through. I would be interested in seeing what you have, and am still interested in finding both pieces, along with the oil lamp bracket.
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Wed Apr 23, 2025 2:45 pm
Ok so I looked thru my stash no lower but I do have a upper with orignal glass dirty needs paint. I do have a lower but the corner is cracked at the joint
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Post by Shrshot » Wed Apr 23, 2025 8:54 pm
Austin, Facebook marketplace has one listed in Stevens Point, WI. for sale.
https://www.facebook.com/marketplace/it ... tn__=!%3AD
Last Name: Hatch
Post by Dan Hatch » Wed Apr 23, 2025 9:27 pm
You coming to Luray? I got an NOS bottom and pretty sure got a top somewhere.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Wed Apr 23, 2025 10:19 pm
Thank you all! Thanks shrshot, im talking to the man with the one in Winsconsin. Thanks for the lead, it has all the parts im loooking for.
Karl, thank you for looking in your stuff. As of now l hope to purchase the one from stephens point, but if it doesn't work out, i will let you know.
Dan, I do not plan on coming to luray this year, if the other deals fall through, I will keep you in mind. My bottom half of the windshield took the brunt of the damage.
Thanks guys!
Austin Farmer
36mike
Last Name: Russell
* REQUIRED* Type and Year of Model Ts owned: 1926 Runabout, 1922 Pickup Express,
Post by 36mike » Fri Apr 25, 2025 10:07 am
Austin, I looks like you have everything under control. I have the lamp bracket and a stack of windshield frames that I can't identify. I am in central Missouri. I have lots of Model T stuff to look at.
Mike
