Starter Jam
Monty 98
First Name: Henry
Last Name: Hocker
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring, 1920-ish Runabout
Starter Jam
Post by Monty 98 » Wed Apr 23, 2025 8:22 pm
Motor kicked back a bit when starting, now won't turn over (sounds like it's trying). Battery, switch, power to starter seems ok. is the bendix jammed into the flywheel?
No Bird Soars in a Calm - Wilbur Wright
Re: Starter Jam
Post by RajoRacer » Wed Apr 23, 2025 8:28 pm
It appears so ! Throw the handbrake forward & rock the car. BTW - the Bendix bolts should be straight across from each other !
Monty 98
First Name: Henry
Last Name: Hocker
Re: Starter Jam
Post by Monty 98 » Wed Apr 23, 2025 8:37 pm
Tried rocking before pulling the cover. is there another method?
Last Name: Hatch
Re: Starter Jam
Post by Dan Hatch » Wed Apr 23, 2025 9:22 pm
Looks like someone is using a 12 volt battery.
Bet the ring gear is bad.
Might try prying the flywheel back with big screwdriver?
Moxie26
Last Name: Jablonski
Re: Starter Jam
Post by Moxie26 » Wed Apr 23, 2025 9:47 pm
Spring definitely has to be replaced... And were the four mounting bolts of the starter snug or loose when this occurred?
Re: Starter Jam
Post by RajoRacer » Wed Apr 23, 2025 10:07 pm
Too much "advance" can be a cause for Bendix jamming - I'd attempt to grab the Bendix drive at the outboard spring bolt with a large pipe wrench or a large adjustable jaw pliers & manipulate the drive back & forth - see what happens !
Re: Starter Jam
Post by Jerry VanOoteghem » Thu Apr 24, 2025 6:34 am
As Steve suggests, grab the end of the bendix and turn it counterclockwise. And yes, your bendix spring is distorted and should probably be replaced.
First Name: Adrian
Last Name: Whiteman
Re: Starter Jam
Post by A Whiteman » Thu Apr 24, 2025 6:49 am
Hi Henry, I had the same issue for much the same cause (son in law learning to drive..).
I removed the Bendix bolts and slid as much off the shaft as possible (the gear was still locked up), then I undid the starter mount bolts. When the starter was loosened the Bendix gear came free from binding on the ring.
Removed the starter and checked shaft had not bent, inspected the gear for damage (none found) then reinstalled and put the Bendix back on again.
(And yes, I had tried the rocking thing before dismantling). Took all of 40mins start to finish to get it going again.
Good luck
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Re: Starter Jam
Post by Shrshot » Thu Apr 24, 2025 10:15 am
Henry, Check the woodruff key that it hasn't sheared part way. May be the cause for misaligned bolts. had it happen to me. Not retarding the spark advance can cause it to happen.
Re: Starter Jam
Post by Allan » Thu Apr 24, 2025 7:05 pm
In my experience the bendix jams on a worn ring gear. All things equal, the things will work well until they don't. The kickback means the gear teeth can often engage on a different face on the worn ring gear. Once it is disengaged normal service may mean that the worn ring gear will carry on as usual, until it doesn't. The only lasting cure is a new ring gear.
Re the bendix spring, I have seen far worse springs than that one still giving good service. Sure, the bolts are aligned on a new spring, but that is not necessarily a reason to replace one as straight as this one. When they start to unwind and distort, then they need replacing.
Trford
First Name: Thomas
Last Name: Ford
Re: Starter Jam
Post by Trford » Thu Apr 24, 2025 9:26 pm
Mine sticks once in a while but releases when I pull the hand crank just a bit. Perhaps your spark wasn’t fully retarded. Just a thought. Good luck.
Re: Starter Jam
Post by speedytinc » Fri Apr 25, 2025 11:36 am
Correct.
As mentioned, Turn the bendix CCW to disengage it from the ring gear & get back into its starting position on the drive thread. If necessary, loosen the starter mount screws. You will be able to view sections of the ring gear. Determine how bad the teeth are damaged.
If gear teeth look serviceable, re-tighten the starter. Turn the starter shaft, looking to see if it is bent. If a hint of bent, remove the bendix, Spin the shaft & straighten the shaft. Replace the bendix. It should slide into the starter snout bearing easily. If not, the snout is also bent. Straightening the snout will require removing the bendix & the starter motor for some bench manipulation.
Re: Starter Jam
Post by Jerry VanOoteghem » Fri Apr 25, 2025 12:16 pm
This area here concerns me. It appears that the counterweight has been driven up hard against the hogshead. It would be difficult to believe that the starter housing and/or starter shaft has not been bent in order to do that.
Either way, you first need to get it unstuck. You have had a lot of good advice in order to do that. Have you made any progress?
Monty 98
First Name: Henry
Last Name: Hocker
Re: Starter Jam
Post by Monty 98 » Fri Apr 25, 2025 3:43 pm
Very good advice. Hope to try loosening the starter screws a little to to see if slight movement will free it. If not, bendix comes off
Re: Starter Jam
Post by Allan » Sat Apr 26, 2025 9:11 am
Well spotted Jerry. It may be that jamming the bendix gear teeth on worn ring gear teeth is causing the dislpacement. Once freed up, hopefully the starter shaft is not bent.
Monty 98
First Name: Henry
Last Name: Hocker
Re: Starter Jam
Post by Monty 98 » Sun Apr 27, 2025 1:37 pm
Loosening the starter worked. New bendix spring ordered. Shaft looks straight. Thanks for the help
Re: Starter Jam
Post by speedytinc » Sun Apr 27, 2025 3:20 pm
Something is way off for the bendix counterweight to hit the hole on one side & lots of clearance on the other side. (if the pix didnt lie)
"Looks straight" Aint gonna cut it. Spin the motor with the bendix off & watch the shaft. After confirming a straight shaft, slide the bendix on. It should effortlessly slide into the starter snout bushing. If not, the snout is bent.
Re: Starter Jam
Post by RajoRacer » Sun Apr 27, 2025 4:23 pm
The closeness of the counterweight to the side might have been a camera angle matter - if not, there would be a "tattle-tail" where it was rubbing.
