WTB - Atlas water pump - found
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Mon Apr 28, 2025 6:29 pm
I'm looking for an Atlas water pump, as seen in this photo:
Atlas water pump.png (258.05 KiB) Viewed 3129 times
Does anybody have one gathering dust on the shelf?
Keep crankin',
Eric
First Name: Henry
Last Name: Lee
Re: WTB - Atlas water pump
Post by Henry K. Lee » Mon Apr 28, 2025 6:36 pm
Eric I have a restored one but the mounting bracket has been cut down for a special project that did not go as planned. Can be easily made from sheet steel.
Hank 4two38three75seven09
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Mon Apr 28, 2025 7:07 pm
email sent, Hank.
ewdysar
First Name: Eric
Last Name: D
Re: WTB - Atlas water pump - found
Post by ewdysar » Mon Apr 28, 2025 8:37 pm
Done deal. Thanks, Hank!
Post by RajoRacer » Mon Apr 28, 2025 8:41 pm
I most likely have an original mounting plate, if you need one - I have a box full of Atlas circulators !
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Mon Apr 28, 2025 8:54 pm
Thanks Steve.
I'll keep that in mind when everything is coming together. I hope that this will be one of the answers for getting Robin Pharis' #32 back on the road with a "C" crank and Roof 8 "Liberty" head. However, all the mounts are custom (motor, R&P steering, suspension, radiator, etc.), so I'll have to see where the pump end of the engine sits, relative to the radiator, once all of these bits and pieces come back together.
Keep crankin',
Eric
elliott1936
Last Name: Elliott
Post by elliott1936 » Tue Apr 29, 2025 11:34 am
Eric:
Thanks for the purchase. I like the idea that you are working on speedster32 so fast.
Tom
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Fri May 02, 2025 5:34 pm
The Atlas is in my hands. Thanks Hank! On to the next challenge...
Keep crankin',
Eric
