Aluminum Head Electrolysis
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Post by SurveyKing » Fri May 02, 2025 6:51 pm
Has anyone had any experience using a product "Lucas Oil Super Coolant" in their Ts with aluminum heads to control electrolysis?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Aluminum Head Electrolysis
Post by Kevin Pharis » Fri May 02, 2025 7:19 pm
Looks to be equivalent to Red Line’s Water Wetter, which I have used for a while and am happy. Note the part where it says “does not protect from freezing”, not a problem for me here in Califunny, but might be in other parts of the world
https://www.lucasoil.com/pdf/03_ProblmS ... nt_PDS.pdf
Post by TRDxB2 » Fri May 02, 2025 8:05 pm
From DeWitts Radiator Company... So it would follow for heads
Do Aluminum Radiators Need Special Coolant?
The key to maximizing the life of an aluminum radiator is not so much the radiator coolant brand as it is the water type. All coolants sold today will protect aluminum radiators. This wasn’t always the case, however. Traditional copper/brass construction was the primary radiator material for six or seven decades and most coolants sold over the counter at your favorite parts store did not have the proper additive and protection package for aluminum radiators. So, you had to be cognizant of not only your radiator’s build materials, but what radiator coolant you were purchasing. Today, all modern coolant brands are sold with the ability to work in traditional copper/brass construction, aluminum and composite construction, and full aluminum construction with a coolant additive for aluminum radiators.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Fri May 02, 2025 9:12 pm
Kevin, I think lang's sells the "Water Wetter". Can it be used with antifreeze, since it, by itself won't protect from freezing?
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Fri May 02, 2025 10:26 pm
The Jaguar guys use modern Green coolant with distilled. They have alot at stake.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri May 02, 2025 11:27 pm
From the Lucas data sheet;
