Wanted Delco 5195 Two Cap Distributor
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Sun May 04, 2025 9:28 pm
I am searching for a Delco 5195 Two Cap Distributor. Originally used on four cylinder Stutz and other makes.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Wanted Delco 5195 Two Cap Distributor
Post by ThreePedalTapDancer » Sun May 04, 2025 11:32 pm
There was someone with one on this thread.
viewtopic.php?f=2&t=47917&p=362689&hilit=Delco#p362689
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Mon May 05, 2025 9:25 am
Have you checked with Tom VanMeeteren? He's a forum member who might have what you need.
rendo
First Name: JOHN
Last Name: RENDEMONTI
* REQUIRED* Type and Year of Model Ts owned: 1925 two door sedan
Post by rendo » Tue May 06, 2025 1:17 pm
You do not need one. The mount on the engine is for a standard magneto.
John
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Fri Sep 19, 2025 1:02 pm
My head is a dual plug head.
T4Tom
Last Name: Magee
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster
Post by T4Tom » Fri Sep 19, 2025 3:18 pm
Chris, check out what Tim Dickson has to offer. Here is his website: https://www.dicksonautomotiverestoration.com
At one point Tim offered a dual distributor unit but I am not seeing it on his website, maybe they are still available. Tim also sells a dual spark, single distributor that is made with modern, easy to find components.
I bought the Delco dual distributor from John Karvaly but it is not for sale.
Tom
