Model T Roadster Pickup with 1924 Engine (price reduced)
JMallak
Topic author - Posts: 4
- Last Name: Mallak
- * REQUIRED* Type and Year of Model Ts owned: 1925 Model T
- Board Member Since: 2025
1924 Engine, 1925 Pickup Box, 1926 Rear End
Rebuilt mechanically from front to back. New rubber. Crank start.
Includes engine stand, Model T tool set and misc. parts and tools.
$12,000.00, Contact John @ 320-582-1737, Hutchinson, MN
JMallak
- Last Name: Mallak
Re: Model T Roadster Pickup with 1924 Engine
From my youth on the farm I remember the crank starts and I always had an affection for wood spoke wheels. In my later years, I wanted to bring a Model T back to life. This ‘24 T was a deliberate build that I wanted to look old but be solid. And as a machinist I wanted to fit this T correctly and functionally.
Some of the additional details;
engine overhauled
radiator rebuilt
transmission overhauled
new pins and bushings
Kevlar bands
jack rabbit clutch
new universal joint
new driveshaft bushing, housing bored and bushing machined to match
new thrust washers in rear end, machined for fit and function
new brake linings
leaf springs taken apart, painted with graphite paint and reassembled
rebuilt pickup box
new floor
new u-channel
new floor boards
Feel free to provide feedback. Thanks, John
engine overhauled
radiator rebuilt
Kevlar bands
jack rabbit clutch
new universal joint
new brake linings
rebuilt pickup box
new floor
new u-channel
new floor boards
JMallak
- Last Name: Mallak
Re: Model T Roadster Pickup with 1924 Engine (price reduced)
New price is $9500
Where is the battery access cover?
Walt Wise
- First Name: Walt
- Last Name: Wise
I'm guessing with no generator and a crank start, if it has a battery at all, it is probably just a small one possibly under the seat just to buzz the coils for battery start, then switch to mag...but who knows...
I don't believe Ford would have made these pickup boxes without the battery access plate since it was a $25 option anyway.
TFan
- First Name: Jim
- Last Name: Riedy
If you look at the photo of the underside of the bed there is no battery or holder frame to be seen. Jim
JMallak
- Last Name: Mallak
I wasn't able to locate any pickup bed rails correct for 1925, so I decided to build a floor that was period correct. The battery box was omitted and I mounted a small battery under the dash to buzz the coils.
