MYSTERY PART
Mark Chaffin
Last Name: Chaffin
MYSTERY PART
Post by Mark Chaffin » Fri May 16, 2025 2:56 pm
Found these at a recent estate sale. Not likely T. Similar to Model A front axle spring perch. I'm calling on the antique car gurus to possibly identify the application.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: MYSTERY PART
Post by Dan McEachern » Fri May 16, 2025 3:05 pm
Aftermarket hot rod front spring perches.
Mark Chaffin
Last Name: Chaffin
Re: MYSTERY PART
Post by Mark Chaffin » Fri May 16, 2025 3:21 pm
I thought so as well; however, they appear old and threads are dipped in wax.
Mark Chaffin
Last Name: Chaffin
Re: MYSTERY PART
Post by Mark Chaffin » Fri May 16, 2025 3:25 pm
You may be right Dan.
Re: MYSTERY PART
Post by TRDxB2 » Fri May 16, 2025 7:01 pm
Good for Bucket T
Re: MYSTERY PART
Post by Allan » Fri May 16, 2025 8:51 pm
The dippped threads are typical of military spec preservaton of spares. That also would indicate an older manufacture.
pete eastwood
First Name: Pete
Last Name: Eastwood
Re: MYSTERY PART
Post by pete eastwood » Fri May 16, 2025 11:40 pm
Those are "PSI" brand spring perches.
PSI was in business in the 60's & 70's & 80's making hot rod stuff.
They were in Rosemead Calif.
Mark Chaffin
Last Name: Chaffin
Re: MYSTERY PART
Post by Mark Chaffin » Sat May 17, 2025 3:22 pm
Thank you Dan and Pete. Makes perfect sense to me. :)
tdump
First Name: Mack
Last Name: Cole
Re: MYSTERY PART
Post by tdump » Sat May 17, 2025 6:42 pm
i wonder if they would work in a stock T axle?? that would lower the car a bit
First Name: Henry
Last Name: Lee
Re: MYSTERY PART
Post by Henry K. Lee » Sat May 17, 2025 6:58 pm
Those were made for split adjustable hair pin radius rods…, so you could dial in the caster!
CamMan
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: '26 Tudor, '22 speedster, ABC/Rajo
Re: MYSTERY PART
Post by CamMan » Tue May 20, 2025 7:58 pm
I haven't seen that idea before, but it should allow lowering the car by dearching of the spring. If you did that with a standard perch the suspension geometry would screwed up.
