Model A Ford distributor ( re-built)( SOLD Thanks MTFCA)
Gene_French
Topic author - Posts: 1099
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
re-built distributor for model A Ford ... was used briefly on re-built engine that was upgraded to a high compression cylinder head and model B distributor ... probably less than 500 miles use on new bushings , points , condenser ...modern points plate etc. ...used cap is included to complete the unit ...price $100 + $19.15 flat rate postage in lower 48 states ...actual postage outside this area ...Gene French 970-581-2808 or gfrench1953@hotmail.com
