FS hood shelves
Karl Von Neumann
Topic author - Posts: 894
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
FS hood shelves
Hood shelves pair in primer 50$ plus the ride fits 17 to 25. Rest are singles 15 each plus the ride
Re: FS hood shelves
For interest sake only, the primed shelves are not an exact pair, but easily made to be same. The one on the left is the latest style, having the big hole at the front for the hard rubber grommet that protects the headlight wiring. The other one has an inverted U shaped cutout in the inner edge to allow the wiring to go under the shelf. This is an earlier iteration of the shelf. These are scarce.
Karl Von Neumann
- First Name: Karl
Re: FS hood shelves
Thanks for pointing that out Allan I didn't noticeAllan wrote: ↑Thu May 29, 2025 4:16 amFor interest sake only, the primed shelves are not an exact pair, but easily made to be same. The one on the left is the latest style, having the big hole at the front for the hard rubber grommet that protects the headlight wiring. The other one has an inverted U shaped cutout in the inner edge to allow the wiring to go under the shelf. This is an earlier iteration of the shelf. These are scarce.
Karl Von Neumann
- First Name: Karl
