Anyone have 8 and/or 10 hp Model A flywheel weight?
For all the models before the Model T
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Thu May 29, 2025 9:28 am
I’m looking for the weight of both the 16 inch (primarily 10 hp A) and 20 inch (8 hp) flywheel. If anyone has a n A motor apart I would appreciate the weight and measurement of the flywheel. If the crank is still attached, the weight of both is good too.
The Model C flywheel should be the same as the 10 hp A, but if anyone has the “C” flywheel by all means please weigh and post that weight too.
Thank you in advance. I’ll post results and other info as we learn more.
Cheers,
Rob
